Configuration guidelines for Cisco871-K9 Model
May 23rd, 2008
I'm a novice having difficulty with configuring my 871 router with the virgin network on a cable modem. If anyone can give me a set of guidelines for this I'd be grateful.
paolo bevilacqua Fri, 05/23/2008 - 08:20
  • Hall of Fame,
    Founding Member
Post actual configuration and someone may have it corrected for you.
ashley1234 Sat, 05/24/2008 - 01:06
Thanks a lot, Mark, a section of the config file is here, if you need more let me know. As you can see the clock is wrong for a start. I'm not sure whether to configure the router as dns server or use the virgin dns servers 62.253.162.237 and 194.168.4.237. ? also the question of static or dynamic routing? I have previously used a mercury K0B RI00 router which works fine on the dynamic/cable modem setting, I will include these settings in case it's useful.
clock timezone PCTime 0
clock summer-time PCTime date Mar 30 2003 1:00 Oct 26 2003 2:00
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp pool sdm-pool1
import all
network 10.10.10.0 255.255.255.0
dns-server 10.10.10.1
default-router 10.10.10.1
interface FastEthernet0
no cdp enable
interface FastEthernet1
no cdp enable
interface FastEthernet2
no cdp enable
interface FastEthernet3
no cdp enable
interface FastEthernet4
description $ES_WAN$$FW_OUTSIDE$
ip address 192.168.1.10 255.255.255.0
ip access-group 101 in
ip verify unicast reverse-path
ip nat outside
ip inspect DEFAULT100 out
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
no cdp enable
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 10.10.10.1 255.255.255.0
ip access-group 100 in
ip nat inside
ip route-cache flow
ip tcp adjust-mss 1452
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet4
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface FastEthernet4 overload
ip nat inside source static tcp 10.10.10.2 23 interface FastEthernet4 23
logging trap debugging
line con 0
login local
no modem enable
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
Here are the settings for the Mercury router which works fine -
Connection Type Dynamic IP
WAN IP 82.22.8.84
Subnet Mask 255.255.252.0
Gateway 82.22.8.1
DNS 62.253.162.237
Secondary DNS 194.168.4.237
LAN
IP Address 192.168.1.1
Subnet Mask 255.255.255.0
DHCP Server Enabled
Firewall Enabled
INFORMATION
System Time 2008/05/24 09:03:23
System Boot Up Time 00007 days 22:40:22
Connected Clients 0
Runtime Code Version V2.00.0096
Boot Code Version V2.00.34
LAN MAC Address 00-40-F4-FD-B8-A8
WAN MAC Address 00-40-F4-FD-B8-A9
paolo bevilacqua Sat, 05/24/2008 - 05:11
  • Hall of Fame,
    Founding Member
You configure:
dns-server 62.253.162.237 194.168.4.237
int fa4
ip address dhcp
no ip access-group 101 in
no ip verify unicast reverse-path
no ip inspect DEFAULT100 out
no ip route-cache flow
int vlan1
no access-group 100 in
no ip tcp adjust-mss 1452
no ip http server
no ip http secure-server
no ip nat inside source static tcp 10.10.10.2 23 interface FastEthernet4 23
ip nat inside source static tcp 10.10.10.2 23 interface FastEthernet4 230
no ip route 0.0.0.0 0.0.0.0 fa4
access-list 1 permit 10.10.10.0 0.0.0.255
That should get you going. To telnet from outside to your .2 device, telnet to the address of the router, port 230. The route can also use Dynamic DNS so you always know which address it got.
Hope this helps, please rate post i it does!
ashley1234 Mon, 05/26/2008 - 02:29
Configured as requested, but must be doing something wrong somewhere as there is still no internet connectivity. The ethernet cable to my pc is on f3 by the way.
Please have a look at the current configuration and advise what to do next.
Thanks!
Building configuration...
Current configuration : 3727 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
resource policy
ip subnet-zero
ip cef
ip dhcp excluded-address 10.10.10.249 10.10.10.254
import all
ip name-server 62.253.162.237
ip name-server 194.168.4.237
no ip address
duplex auto
speed auto
interface Vlan1
ip classless
ip http server
no cdp run
control-plane
banner login ^C
^C
line con 0
login local
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
end
Mark Yeates Mon, 05/26/2008 - 03:16
  • Gold, 750 points or more
Ashley,
You will need to implement NAT (Network Address Translation) on your router to be able to access the internet on the inside of your network. Please input the following lines into your router.
access-list 1 remark NAT_ACL
ip nat outside
interface Vlan1
ip nat inside
This will allow you to utilize all four switchports.
Mark
ashley1234 Mon, 05/26/2008 - 04:52
Done, but still no connection. I note that in SDM
the WAN type is unsupported and has no ip address. Here is the latest configuration:
Current configuration : 3910 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
ip cef
import all
no ip address
ip nat outside
duplex auto
speed auto
interface Vlan1
ip nat inside
ip classless
ip http server
no cdp run
control-plane
banner login ^C
^C
line con 0
login local
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
end
Mark Yeates Sat, 05/24/2008 - 09:19
Do you have an NTP server on your network? I usually recommend the use of a NTP server to synchronize the clock on the router. I use a public server for my home equipment. Feel free to use the below statements to update the time on your router.
ntp server 207.46.130.100 source FastEthernet4 prefer
ntp server 192.43.244.18 source FastEthernet4
and these for your appropriate timezone.
clock timezone Central -6
clock summer-time CDT recurring
If there is anything else you need help with let us know.
Mark
ashley1234 Sat, 05/24/2008 - 11:51
Much appreciated, will let you know how everything went.
ashley1234 Mon, 05/26/2008 - 03:03
Mark, configured the ntp server, but still no web access or net connectivity. Here is my current configuration, can you tell me what's wrong?
I can post ipconfig /all results from the pc command line if you need it.
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
ip cef
import all
no ip address
duplex auto
speed auto
interface Vlan1
ip classless
ip http server
no cdp run
control-plane
banner login ^C
^C
line con 0
login local
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
end
paolo bevilacqua Mon, 05/26/2008 - 05:03
  • Hall of Fame,
    Founding Member
Please review my configuration above, you're mssing "ip address dhcp" and many other commands.
ashley1234 Mon, 05/26/2008 - 06:15
I've re-entered all the commands in your list, and I see that the WAN interface in SDM is unsupported, there is no ip address. Where do I go from here?
ashley1234 Mon, 05/26/2008 - 06:17
also, should I configure default gateway and gateway of last resort, and if so, how?
Ashley
paolo bevilacqua Mon, 05/26/2008 - 06:20
  • Hall of Fame,
    Founding Member
No, that is not needed.
Please use the CLI exclusively to configure the router. With SDM you've no guarantee whatsoever to get it working.
markyeates Mon, 05/26/2008 - 07:25
I noticed two things that are preventing web access from working. Are you using a modem of somesort ie.. cable/DSL? I notice that fastethernet 4 does not have an IP address. If you are using a DHCP address for your outside IP address please add this command to FA4. If not add the static IP address from your ISP.
ip address dhcp
I also see that you don't have a default route. paste the following command.
You should also re add your DHCP pool with the addition to the default router command.
import all
Hope this helps
Mark
paolo bevilacqua Mon, 05/26/2008 - 07:38
  • Hall of Fame,
    Founding Member
Hi, this command:
Is always wrong for two reasons:
First, when router get an address via DHCP, it also install a default static route automatically, so it's not needed.
Second, even if router had a static IP address, a route referencing a LAN interface instead of an IP address, causes router to ARP for any destination.
That is not the inteded behavoir, so for routes going via LAN interface one should always use IP addresses, and not the interface itself.
Mark Yeates Mon, 05/26/2008 - 08:44
Thanks for the clarification. I usually don't configure it that way, As I wasn't sure if she needed a static IP or a DHCP address. I was going to advise her to change it after the router is configured, and passing traffic.
Mark
ashley1234 Mon, 05/26/2008 - 10:34
All done, except for the ip route command which was advised against. Still no connection however.
In case it helps, here is information about my cable modem. Thus far have been unable to update the driver.
Cable Modem Information
Cable Modem : Euro-DOCSIS 1.0/1.1/2.0 Compliant
MAC Address : 00:14:a4:c9:8d:f7
Serial Number : 0014A4C98DF7
Boot Code Version : 3.1.6d
Software Version : 2.94.1014
Hardware Version : 1.19
Modem status
Acquire a Downstream Channel 586750000 Hz Locked
Connectivity State OK Operational
Boot State OK Operational
Cable Modem Downstream
Downstream Lock : Locked
Downstream Channel Id : 2
Downstream Frequency : 586750000 Hz
Downstream Modulation : QAM256
Downstream Symbol Rate : 6952 Ksym/sec
Downstream Interleave Depth : taps12Increment17
Downstream Receive Power Level : 3.5 dBmV
Downstream SNR : 33.4 dB
Cable Modem Upstream
Upstream Lock : Locked
Upstream Channel ID : 3
Upstream Frequency : 42800000 Hz
Upstream Modulation : QAM16
Upstream Symbol Rate : 2560 Ksym/sec
Upstream transmit Power Level : 46.0 dBmV
Upstream Mini-Slot Size : 2
Cable Modem Operation Configuration
Network Access : Allowed
Maximum Downstream Data Rate : 20480000
Maximum Upstream Data Rate : 768000
Maximum Upstream Channel Burst : 1600
Maximum Number of CPEs : 1
Modem Capability : Concatenation Enabled, Fragametation Enabled, PHS Disabled
ashley1234 Mon, 05/26/2008 - 11:59
carefully typed in all your commands again one by one, still no luck?, also configured NAT per Mark's instructions. It seems the WAN interface is not recieving an ip address via dhcp and is unsupported in SDM? what am I missing?
Ashley
paolo bevilacqua Mon, 05/26/2008 - 12:07
  • Hall of Fame,
    Founding Member
Again, do not rely on the SDM.
Sometime, the DHCP client in cisco routers is incompatible. Can you send output of "show interface fa4" ?
ashley1234 Mon, 05/26/2008 - 23:21
Output of "show interface f4":
Router#show interface fa4
FastEthernet4 is up, line protocol is up
Hardware is PQUICC_FEC, address is 001e.7a3d.1e80 (bia 001e.7a3d.1e80)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:27, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
64 packets input, 21888 bytes
Received 64 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
0 lost carrier, 0 no carrier
ashley1234 Tue, 05/27/2008 - 02:27
I must add, I noticed the configuration wasn't being saved when the router was switched off so I re-entered all requested commands then ran "copy startup-config running-config". the result for "show interface fa4" is now different, you can see 82.22.11.172/22 has been assigned, still no connectivity however:
Router#sh interface fa4
Internet address is 82.22.11.172/22
Last input 00:00:06, output 00:00:18, output hang never
158 packets input, 44232 bytes
Received 120 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
76 packets output, 7536 bytes, 0 underruns
Also here is the result of the "sh ip route" command:
Router#sh ip route
Gateway of last resort is 82.22.8.1 to network 0.0.0.0
80.0.0.0/32 is subnetted, 1 subnets
S 80.1.224.37 [254/0] via 82.22.8.1, FastEthernet4
82.0.0.0/22 is subnetted, 1 subnets
C 82.22.8.0 is directly connected, FastEthernet4
10.0.0.0/24 is subnetted, 1 subnets
C 10.10.10.0 is directly connected, Vlan1
S* 0.0.0.0/0 [254/0] via 82.22.8.1
paolo bevilacqua Tue, 05/27/2008 - 03:04
  • Hall of Fame,
    Founding Member
Ok, after configuring you have to exit config with ctrl-Z, then enter "write" to save config.
Now from the router try to ping to one of your DNS addresses, or 4.2.2.1
For the lack of connectivity I'm afraid some command is still missing so you will have to send configuration again.
Do not despair, you're almost there.
ashley1234 Tue, 05/27/2008 - 06:25
No problem, your help is invaluable.
clock timezone GMT 0
clock summer-time GMT recurring
ip subnet-zero
ip cef
import all
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
ip nat inside
ip classless
no ip http server
no cdp run
control-plane
banner login ^C
^C
line con 0
login local
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
ntp clock-period 17179760
end
And here is the output from "show ip route" command:
Router#sh ip route
Mark Yeates Tue, 05/27/2008 - 07:45
Ashley,
I am not seeing anything in your config that would prevent you from accessing the web. Please make sure that you PC's have a valid IP address in the 10.10.10.X scope. I do recommend applying the "spanning-tree portfast" command to int fa3 that your PC is connected to. Please keep us posted.
Mark
ashley1234 Tue, 05/27/2008 - 09:41
Done as requested. I notice that I can only access the router with CLI and not SDM at the moment, still no web. At least now when I try ipconfig /all in the pc command line, you see the default gateway 10.10.10.1 and 10.10.10.2 is automatically configured by DHCP. Also 'show ip route' seems to indicate that DHCP is working on fa4, so what's missing? Here is the output from 'do show spanning-tree' command:
Chiron(config)#do show spanning-tree
VLAN1 is executing the ieee compatible Spanning Tree protocol
Bridge Identifier has priority 32768, address 001e.7a3d.1e76
Configured hello time 2, max age 20, forward delay 15
We are the root of the spanning tree
Topology change flag not set, detected flag not set
Number of topology changes 1 last change occurred 01:00:34 ago
from FastEthernet3
Times: hold 1, topology change 35, notification 2
hello 2, max age 20, forward delay 15
Timers: hello 1, topology change 0, notification 0, aging 300
Port 4 (FastEthernet3) of VLAN1 is forwarding
Port path cost 19, Port priority 128, Port Identifier 128.4.
Designated root has priority 32768, address 001e.7a3d.1e76
Designated bridge has priority 32768, address 001e.7a3d.1e76
Designated port id is 128.4, designated path cost 0
Timers: message age 0, forward delay 0, hold 0
Number of transitions to forwarding state: 1
BPDU: sent 1832, received 0
The port is in the portfast mode
paolo bevilacqua Tue, 05/27/2008 - 12:55
  • Hall of Fame,
    Founding Member
Can you ping from router ?
Mark Yeates Tue, 05/27/2008 - 15:13
On that note make sure that you can ping your DNS servers from both your router, and your PC. Based on your config the IP addresses are:
62.253.162.237
194.168.4.237
I think we are getting close to a resolution.
Mark
ashley1234 Tue, 05/27/2008 - 20:37
Yes, I can ping them successfully from both the PC and the router, and most of the other addresses shown in 'show ip route' output. There were two other dns servers shown in the output I had not seen before. I will ping all the addresses again and give you the results.
Ashley
ashley1234 Tue, 05/27/2008 - 21:43
I must correct myself here. I should have said, I can ping the dns servers successfully from the pc while using my mercury router, but NOT from the cisco router, which I tried to communicate with this morning with no success. In my PC command line I typed ipconfig /all and got a different set of results from yesterday. There was an automatic assignment of ip address 169.254.37.215
subnet mask 255.255.0.0, no gateway. I tried pinging the dns servers from the command line, unsuccessfully.
Yesterday the results from ipconfig /all were ip address 10.10.10.2, gateway 10.10.10.1
assigned automatically. I remember this situation happened before, after configuring the cisco router according to instruction. At first, there was an automatic assignment of 10.10.10.2 and CLI was accessible. The following day, I was assigned a similar address to 169.254.37.215 and lost contact with the router. Is there some issue here with DHCP?
Ashley
paolo bevilacqua Wed, 05/28/2008 - 04:57
  • Hall of Fame,
    Founding Member
Please try ping from router accessed via CLI. You can give to a static PC address if any DHCP trouble.
Mark Yeates Wed, 05/28/2008 - 05:49
You will want to ping the IP address (FA4) that was assigned to your router from your ISP.
Mark
ashley1234 Wed, 05/28/2008 - 06:44
Right, I can ping 82.22.8.1 (the adress assigned to fa4) no problem with my mercury router connected, but when I try with the cisco router connected I get destination unreachable on the pc command line and still no way of communicating with the router CLI.
paolo bevilacqua Wed, 05/28/2008 - 10:31
  • Hall of Fame,
    Founding Member
As mentioned before, if the PC doesn't get an address via DHCP, assign statically.
Mark Yeates Wed, 05/28/2008 - 14:21
You are not able to console into the cisco router? I'm not sure if I understand which pings work at this point.
ping from PC to fa4 (DHCP address)
ping from PC to ISP gateway
ping from router to ISP gateway.
From previous posts your fa4 IP was 82.22.11.172
ISP gateway IP 82.22.8.1
Based on your response we will know where we stand at this point.
Mark
ashley1234 Wed, 05/28/2008 - 22:59
I have tried pinging 82.22.11.172 and 82.22.8.1 without success from the command line. When I type ipconfig /all it shows the address 169.254.37.215, subnet 255.255.0.0 has been assigned to my PC, but no gateway. Why did the address change from 10.10.10.2?
Ashley
ashley1234 Thu, 05/29/2008 - 02:04
The latest situation (as of 29th May) is this.
I pressed the reset button on the router and found I was able to access CLI in a telnet putty session on 10.10.10.1 23 Not only that but I could ping all the addresses shown in the 'show ip route' command successfully, both from the router and from the pc. However, the ip address for fa4 had changed to 80.0.59.74. still no web access. Here is the current output from 'Show ip route', 'show ip int brief' and 'sh ip arp' commands:
Router#sh ip route
Gateway of last resort is 80.0.56.1 to network 0.0.0.0
80.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 80.0.56.0/22 is directly connected, FastEthernet4
S 80.1.224.37/32 [254/0] via 80.0.56.1, FastEthernet4
S* 0.0.0.0/0 [254/0] via 80.0.56.1
Router#sh ip int brief
FastEthernet0 unassigned YES unset up down
FastEthernet1 unassigned YES unset up down
FastEthernet2 unassigned YES unset up down
FastEthernet3 unassigned YES unset up up
FastEthernet4 80.0.59.74 YES DHCP up up
Vlan1 10.10.10.1 YES NVRAM up up
NVI0 unassigned YES unset up up
Router#sh ip arp
Protocol Address Age (min) Hardware Addr Type Interface
Internet 10.10.10.2 7 0016.e64f.c4ad ARPA Vlan1
Internet 10.10.10.1 - 001e.7a3d.1e76 ARPA Vlan1
Internet 80.0.59.74 - 001e.7a3d.1e80 ARPA FastEthernet4
Internet 80.0.56.1 32 0005.74f7.3001 ARPA FastEthernet4
Mark Yeates Thu, 05/29/2008 - 06:15
It sounds like we have made some progress. If you are able to ping outside of the network from the router and PC then things are working fine. Are you sure you have the right DNS server IP addresses added to your router? That's the only thing I can think of why web access doesn't work, but pings do.
ashley1234 Thu, 05/29/2008 - 06:52
I was originally given 62.253.162.237 and 194.168.4.237 as name servers, and when I tried 'show hosts' on CLI I got these plus an additional 194.168.4.100 and 194.168.8.100. I successfully pinged them all.
Mark Yeates Thu, 05/29/2008 - 07:04
That's good that you can ping the IP's. I just want to make sure that they are valid DNS servers. You can test using 4.2.2.1 as a test DNS server.
ashley1234 Thu, 05/29/2008 - 07:43
Yes! I now have full web connectivity. The problem was quite simple, I had omitted to configure my domain name, duh...
Thanks so much for your help. I may need to think of a couple of questions to ask about general security configuration, and just at the moment can't bring up SDM, but that's all. I'd like to rate this message to notify the problem has been solved, but there doesn't seem to be a box yet?
Ashley
Mark Yeates Thu, 05/29/2008 - 13:09
Great. You should be able to rate the conversation. Please start another post with your other questions, as this one was quite difficult to keep up with. Im glad we got the issue resolved, and would glad to still help in the future.
Mark
ashley1234 Tue, 05/27/2008 - 21:48
While I was in contact with the cisco router it was possible to ping most of the addresses in the network. However, as I said to Mark:
Ashley
Mark Yeates Mon, 05/26/2008 - 14:06
Please post the output of the "show ip interface brief" command. I would like to make sure that you are getting an IP address. You also may need to reset the modem for 30-45 seconds. Sometimes that does the trick.
Mark
ashley1234 Mon, 05/26/2008 - 23:20
Here we are, output of "show ip interface brief".
I have tried resetting the modem, still no luck, though it works fine on my Mercury router. The PC connects to fa3.
Router#show ip interface brief (typed in two columns to avoid scrambled output)
Interface FastEthernet0
IP-Address unassigned
OK? YES
Method unset
Status up
Protocol down
Interface FastEthernet1
IP-Adress unassigned
OK? YES
Method unset
Status up
Protocol down
Interface FastEthernet2
OK? YES
Method unset
Status up
Protocol down
Interface FastEthernet3
OK? YES
Method unset
Status up
Protocol up
Interface FastEthernet4
OK? YES
Method NVRAM
Status up
Protocol up
Interface Vlan1
IP-Adress 10.10.10.1
OK? YES
Method NVRAM
Status up
Protocol up
paolo bevilacqua Mon, 05/26/2008 - 23:25
  • Hall of Fame,
    Founding Member
Please send output of "show interface fa4". To see at least if DHCP packets travels on it.
ashley1234 Tue, 05/27/2008 - 02:10
I must add: it seems the running configuration wasn't being saved when the cisco router was switched off and on again so I loaded all the commands again one by one and then input "copy startup-config running-config"
Then the output of "show ip interface brief"
was different. Here it is. Question, I can see
fa4 has now been assigned 82.22.11.172 via DHCP, but still no connectivity? also what is interface NVI0? I also ran "sh ip route" and got interesting results shown below this:
Thanks!
Ashley
Router#sh ip interface brief
OK? YES
Method unset
Status up
Protocol down
OK? YES
Method unset
Status up
Protocol down
OK? YES
Method unset
Status up
Protocol down
OK? YES
Method unset
Status up
Protocol up
IP-Adress 82.22.11.172
OK? YES
Method DHCP
Status up
Protocol up
Interface Vlan1
OK? YES
Method NVRAM
Status up
Protocol up
Interface NVI0
OK? YES
Method unset
Status up
Protocol up
Router#sh ip route
