classic and cef256 module support sup720
Answered Question
May 23rd, 2008
We have WS-X6348-RJ-45, WS-X6324-100FX-MM, WS-X6408A-GBIC and WS-X6816-GBIC ( with daughter card WS-F6K-DFC ). Can these modules work with WS-SUP720-3B and new line card WS-X6724-SFP?
Best Regards,
Correct Answer by gpulos about 9 years 2 days ago
Answers are as follows:
WS-X6724-SFP = YES
WS-X6348-RJ-45 = YES
WS-X6324-100FX-MM = YES
WS-F6K-DFC = NO
(use WS-F6K-DFC3B or WS-F6K-DFC3BXL; for 65xx/6816 modules)
(or use WS-F6700-DFC3B or WS-F6700-DFC3BXL; for 6700 modules)
WS-X6408A-GBIC = YES
WS-X6816-GBIC = YES
Please see the following link for the 6500 Relevant Interfaces and Modules matrix:
http://www.cisco.com/en/US/products/hw/switches/ps708/products_relevant_interfaces_and_modules.html
Please see the following link for some switching modules/sup720 support info:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/release/notes/OL_4164.html#wp2563690
Overall Rating: 5 (1 ratings)
Correct Answer
gpulos Fri, 05/23/2008 - 02:45
  • Blue, 1500 points or more
WS-X6724-SFP = YES
WS-F6K-DFC = NO
WS-X6816-GBIC = YES
andrew.butterworth Fri, 05/23/2008 - 03:20
  • Gold, 750 points or more
The linecards will work (except the DFC) however classic linecards (and CEF256) will affect the performance of the chassis. To get the best performance you need to use all CEF720 linecards, if you use Classic modules then the chassis has to fallback (to some extent) for compatibility.
I saw some marketing slides last year regarding the architecture of the 6500 and how different types of linecards interact. The switching paths with mixed linecards is pretty much all over the place....
Andy
