05-23-2008 02:43 AM - edited 03-15-2019 10:50 AM
Hi guys wonder if anyone could give me a hand here, its the first time i am installing and configuring a VGW for one of our sites, everything seems to be working the calls are incoming into the GW as i can see, but they dont seem to be translating properly.. if anyone could tell me where im going wrong it would be appreciative :) the number range is 0207 510 9340 - 9369 which im trying to translate into the 7000 exntension range
hostname DR-VGW
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret xxx
no aaa new-model
resource policy
network-clock-participate wic 0
ip subnet-zero
ip cef
no ip domain lookup
ip domain name yourdomain.com
ip host etg-ccm02 10.5
ip host etg-ccm01.yourdomain.com 10.
isdn switch-type primary-net5
voice-card 0
no dspfarm
voice rtp send-recv
voice class codec 1000
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
voice class h323 1
h225 timeout tcp establish 5
voice translation-rule 90
rule 1 /^....$/ /&/
rule 2 /^......$/ /&/
rule 3 /^1/ /901/
rule 4 /^2/ /902/
rule 5 /^3/ /903/
rule 6 /^4/ /904/
rule 7 /^5/ /905/
rule 8 /^6/ /906/
rule 9 /^7/ /907/
rule 10 /^8/ /908/
rule 11 /^9/ /909/
rule 12 /^0/ /900/
voice translation-rule 7000
rule 1 /^5109/ /7/
rule 2 /^109/ /7/
rule 3 /^09/ /7/
rule 4 /^9/ /7/
voice translation-rule 75109430
rule 1 /^7.../ /75109340/
voice translation-profile Inbound_Translation
translate calling 90
translate called 7000
voice translation-profile Outbound-CLI
translate calling 75109430
controller E1 0/0/0
pri-group timeslots 1-30
controller E1 0/0/1
interface FastEthernet0/0
description ***Lan Interface***
ip address 10. 255.255.255.0
duplex auto
speed auto
h323-gateway voip bind srcaddr 10.
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
isdn incoming-voice voice
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 10.
no ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
control-plane
voice-port 0/0/0:15
input gain 6
echo-cancel coverage 32
cptone GB
timeouts interdigit 4
bearer-cap Speech
dial-peer voice 90 pots
description ***Outbound PSTN Calls***
translation-profile incoming Inbound_Translation
translation-profile outgoing Outbound-CLI
destination-pattern 9T
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
incoming called-number .
direct-inward-dial
port 0/0/0:15
dial-peer voice 7000 voip
destination-pattern 7...
progress_ind setup enable 3
no modem passthrough
voice-class codec 1000
voice-class h323 1
session target dns:etg-ccm02
dtmf-relay h245-alphanumeric
fax-relay ecm disable
ip qos dscp cs3 signaling
no vad
dial-peer voice 7001 voip
preference 1
voice-class h323 1
session target dns:etg-ccm01
no vad
dial-peer voice 91 voip
description ***Outbound PSTN Calls (backup dial peer to TRA GW)***
preference 1
session target ipv4:
05-23-2008 08:56 PM
If you want to send out individual number, then change;
rule 1 /^7.../ /75109340/ <--- this to
rule 1 /^7\(...\)/ /75109\1/
assuming that last 3 digits of your internal extensions matches the last 3 digits of your inbound number range.
voice translation-profile Outbound_Mask
voice translation-rule 2
rule 1 /^9\(3..\)/ /7\1/
voice translation-profile Internal_Ext
translate called 2
If PSTN is sending 4 digits to your router.
voice-port 0/0/0:15
translation-profile outgoing Outbound_Mask
translation-profile incoming Internal_Ext
dial-peer voice 1 pots
destination-address 7...
direct-dial-inward
port 0/0/0:15
