Add new CCM to cluster
May 23rd, 2008
In my office i have one CCM 5.3
Now i want add second CCM 5.3 for voice mail
When i run installation from CD all install is normal, but after setup ask me about "SI you server fist node in the cluster" i set "NO"
set my first CCM ip and sequrity pass, but it doesnt work :( maybe pass wrong? Where i must change sequrity passwd?
Aaron Harrison Sun, 05/25/2008 - 05:46
  • Community Spotlight Award,
    Member's Choice, May 2015
You can set the security password from the console or SSH to the existing CallManager.
Use this command:
set password security
It will then prompt you for the old/new passwords.
Aaron
Please rate helpful posts...
Jaime Valencia Sun, 05/25/2008 - 13:22
  • Cisco Employee,
  • Hall of Fame,
    2011
have you added the SUB into the PUB config before installing the new server?
javalenc
if this helps, please rate
Jaime Valencia Mon, 05/26/2008 - 08:03
  • Cisco Employee,
  • Hall of Fame,
    2011
PUBlisher, SUBscriber
javalenc
