acs4.1 & aaa authorization & permit show
May 23rd, 2008
Selam,
I want to deny all commands except "show run" for a group and for all network devices.
So I created a group on acs4.1 and attached with a "Shell Command Authorization Set" ("permit show runnig-config" - "deny unmatched commands")
than I used commands which you can see below:
aaa authorization exec default group tacacs+ local
aaa authorization commands 1 default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ if-authenticated
NOW: rules are runnig for my new group but other groups which have full access for all devices are failing (% Authorization failed)
what can be the problem?
Ozlem
rochopra Fri, 05/23/2008 - 05:01
  • Cisco Employee,
create another shell command authorization set for full access group and configure it for "unmatched commands - permit"
and do not enter any command for it.
That will work for you.
~Rohit
