MLPPP with HWIC-4T1/E1 card...
May 23rd, 2008
I've done tons of T1s (with the old T1 WIC card), and tons of frame-relay, but this is my first time doing MultiLink PPP. Can someone scrub the config below, to see if it's OK? I'm using five (5) individual T1s; and the carrier said they're all in "up/down" state; no line-protocol. I see the same on my side, everything is "up/down". Am I missing something having to do with PPP? Router is a new 2851, and the IOS i'm running is shown in the config.
Config is attached!
abatson Fri, 05/23/2008 - 05:51
Original poster here: It's been a while since I've configured a T1 controller, I usually deal with the WIC-1DSU-T1's.
I think I see my error:
If I'm using "channel-group 1 timeslots 24", this means I'm using the 24th channel ONLY, not "all 24 channels", correct?
I need to use "channel-group 1 timeslots 1-24", correct? I guess I interpreted "timeslots" to mean the number of timeslots, not the range of timeslots.
If this is fixed, does the config appear OK?
aravindhs Fri, 05/23/2008 - 08:07
Hi there,
Remove the command from both the routers -
