Lose telnet capability after crypto map
tony_8528
I have 2 DSL routers setup with a VPN tunnel between them. The VPN works fine. Before setting up the tunnel, I had telnet/SSH access. However, when I apply the crypto map to the Dialer interface, I lose the ability to telnet/SSH to the router. If I remove the VPN setup, I regain the ability to telnet/SSH.
Any thoughts? I was wondering if the fact the Dialer interface is a logical interface is what is causing the problems?
Thanks.
Tony
The first thing that stands out is:
interface Vlan1
ip access-group 100 in
interface Dialer0
You don't have an ACL 100 in your config. I would define an ACL for the inside interface based on security policy, and apply inspection on that interface to provision the return path (temporary dynamic holes in the firewall).
Likewise, configure an ACL for the external interface permitting the ISAKMP, ESP, and SSH connections initiated from that side, with inspection to provision the return path.
I think you should be more specific with your NAT ACL:
access-list 120 deny ip 192.168.1.0 0.0.0.255 192.168.5.0 0.0.0.255
access-list 120 permit ip 192.168.1.0 0.0.0.255 any
9 Replies 9
michael.leblanc
Level 4
Level 4
Telnet/SSH access to the far-side router's external interface, or internal hosts?
Might be helpful if you posted the crypto ACLs from both sides.
I can currently telnet/SSH to the 877/827 from the inside (private) LAN connection. I can not telnet/SSH to the routers from the outside (public) connection.
My current workaround is to RDP into a workstation on the LAN and then telnet from that box into the router.
I have setup many of VPN tunnels, both with routers and firewalls. I have never had an issue like this. Just wondering if this is a quirk with the DSL connection. Searching CCO did not give me an answer.
I will post the configs shortly.
Thanks.
Tony
Your statement - "I can not telnet/SSH to the routers from the outside (public) connection."
... isn't completely clear to me.
Are you trying to make these connections through the VPN tunnel (unsuccessfully), or are you talking about difficulties with non-tunneled connections?
I am not trying to telnet/SSH to the router through the tunnel. I am trying to telnet/SSH from another public IP address.
Tunnel from A to B works as expected. I am at location C, completely separate from A or B, trying to telnet/SSH to either A or B. As long as the crypto map is in place, I can not telnet/SSH to either router. If I remove the VPN setup from both A and B, I can then telnet/SSH to either A or B without any problems.
Are you using the "any" keyword in your crypto ACL(s)?
Here is the config. ACL 120 has permit ip any any but it is referenced by NAT not the Crypto. Crypto references ACL 130. I have seen it posted not to put any any in the Crypto ACLs, perhaps this applies to the NAT as well. I will try changing that one. Anyway, here is the config. Pretty straight-forward.
sh run
Building configuration...
Current configuration : 2927 bytes
version 12.4
no service pad
hostname Ashtabula
boot-start-marker
boot-end-marker
enable secret 5
no aaa new-model
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.50
ip dhcp pool Ash-dhcp
network 192.168.1.0 255.255.255.0
dns-server 166.x.x.11 166.102.165.13
default-router 192.168.1.1
lease 7
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
no ip domain lookup
ip domain name Ashtabula.local
ip name-server 166.102.165.11
ip name-server 166.102.165.13
vpdn enable
username
username
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp key xxxxxxxx address xx.xx.xx.xx no-xauth
crypto ipsec transform-set ToMead esp-3des esp-sha-hmac
crypto map Meadville 10 ipsec-isakmp
set peer xx.xx.xx.xx
set transform-set ToMead
match address 130
archive
log config
hidekeys
bridge irb
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
pvc 0/35
pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Vlan1
description LAN
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
bridge-group 10
bridge-group 10 spanning-disabled
interface Dialer0
ip address yy.yy.yy.yy 255.255.255.252
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username xxxxxxx password 0 xxxxxxx
ppp ipcp dns request
ppp ipcp address accept
interface Dialer1
no ip address
no cdp enable
interface BVI10
description Bridge to Internal Network
no ip address
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 192.168.1.0 255.255.255.0 Vlan1
ip http server
no ip http secure-server
ip nat inside source list 120 interface Dialer0 overload
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 120 permit ip any any
access-list 130 permit ip 192.168.1.0 0.0.0.255 192.168.5.0 0.0.0.255
dialer-list 1 protocol ip permit
no cdp run
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
password xxxxxxxxxx
login local
scheduler max-task-time 5000
end
interface Vlan1
interface Dialer0
Sorry for the delay in response. I've been a bit red-faced for 2 reasons. I posted without looking at the config, and it had been changed. There should not have an access-group 100. A bit of embarrassment there. Also done some chewing on someone for making changes without authorization.
Anyway, changing the ACL from any any to be specific to the subnet did solve the issue. Thanks for the help Michael.
Your welcome.
Perhaps you can checkmark the conversation to convey that it includes a reply that solved the issue.
Others experiencing a similar issue might be more prone to make use of the conversation.
