Create process error : \\<ip address of the IPCC>\DESKTOP_CFG\Desktop\Agent
May 23rd, 2008
New install of 3.5.4sr2 with CM4.2.3sr1
When I run:
\\10.0.24.20\DESKTOP_CFG\desktop\InstallManager
I get Create process error : \\10.0.24.191\DESKTOP_CFG\Desktop\Agent
I don't have a 10.0.24.191 in my network. What is this ip address suppose to refer to?
I did a search and found
Switch CTI Server A=10.0.24.191
Switch CTI Server A Type=IPAddress
Switch CTI Port A=42027
So shouldn't my cti server refer to my Callmanager server. Has anyone had this problem and how do I fix this?
ebreniz Thu, 05/29/2008 - 11:23
try the following steps:
First remove the association with IP phone and/or device profile for the user in question.
Second, remove the CTI enable checkmark and click update.
Then delete the user in AD. If you have a resource already deleted and still show up as ICD resource, add back the user in AD
http://www.cisco.com/en/US/products/sw/custcosw/ps1846/products_tech_note09186a00801f978a.shtml
http://www.cisco.com/en/US/products/sw/custcosw/ps1846/products_tech_note09186a00801ecf61.shtml
aamercado Fri, 05/30/2008 - 06:44
Actually, I had to follow the procedure "changing IP address" in the admin quide to fix this but thanks for your reply anyways.
