WIC2T and MLLN
May 23rd, 2008
  • Bronze, 100 points or more
hi,
When i connect 1700 WIC2t to my MLLN circuit, the circuit is comming up on hdlc and pp as well.
But when i budle it with multilink (PP multilink group) it's going down.
Configuration is fine and very less at both ends.
the circuit is BSNL MLLN.
in the same E1 multiple customer routers are working fine with same config.
I have seen some posts and found WIC 2t having issues with MLLN.
any guidance will be helpfule.
paolo bevilacqua Fri, 05/23/2008 - 09:32
  • Hall of Fame,
    Founding Member
You are trying multilink on a single circuit? What's for ?
rajivrajan1 Fri, 05/23/2008 - 09:51
im using crypto tunnels and voice traffic , which are well supported by multilink interface at both sides.
