Cannot write to const_nvram 6509 - Sup720
May 23rd, 2008
My IOS: s72033-ipservicesk9-mz.122-18.SXF12.bin
I cannot do a: "copy tftp const_nvram:vlan.dat"
After a successful tftp transfer, the switch immediately responds with an error to the effect of , "cannot write to const_nvram".
This command works with this IOS, "s72033-jk9sv-mz.122-18.SXD7b.bin"
Any help would be greatly appreciated!
thanks,
Jason
lamav Fri, 05/23/2008 - 08:26
  • Blue, 1500 points or more
In order to restore the vlan.dat file, complete these steps:
Copy the vlan.dat file into the device's NVRAM from a TFTP server or an external PCMCIA card.
copy tftp: const_nvram:
notice no vlan.dat file name present...
Reload the switch, as vlan.dat is read only during the booting process.
Victor
gilbert.jason Fri, 05/23/2008 - 08:58
Tried that and still have the same problem
Here is what I typed.
copy ttp: const_nvram:
I got:
"%Warning: There is a file already existing with this name Do you want to over write? [confirm]
Cannot copy from vlan.dat to vlan.dat"
ita_hsieh Tue, 10/19/2010 - 23:31
Dear Jason:
   Did you happen to solve the problem? I am facing the same issue. Thanks.
FlorianBerthelot Fri, 12/30/2011 - 05:29
Did you manage to solve this issue ? I am having the same, i tried with a
erase const_nvram before the reload but with no luck.
Thanks in advance
amikat Sat, 12/31/2011 - 01:33
  • Silver, 250 points or more
Can you please post the "dir const_nvram:" command output.
Thanks&Regards,
Antonin
FlorianBerthelot Tue, 01/03/2012 - 00:54
Hello Amikat,
Thanks for your reply, dir const_nvram says that vlan.dat
1     -rwx     0          vlan.dat
I also did a
Chassis#erase const_nvram
Erasing the const_nvram filesystem will remove all configuration files! Continue? [confirm]
[OK]
Erase of const_nvram: complete
Chassis#reload
//output....
but no chances, i get :
User Access Verification
Password:
Chassis>en
Chassis#copy bootflash:vlan.dat const_nvram:vlan.dat
Destination filename [vlan.dat]?
%Warning:There is a file already existing with this name
Chassis#exit
Thanks you in advance if you have any ideas...
best regards
amikat Tue, 01/03/2012 - 01:49
Thanks for the reply.
Can you please try to use the command "delete const_nvram:vlan.dat" instead of "erase ..." and if succeed reload the switch and try again the "copy ..." command and see if there is any progress.
Best regards,
Antonin
FlorianBerthelot Tue, 01/03/2012 - 01:52
Hi again, same issu when I use the delete command... I will make some tests today and let you know, I did follow the Cisco procedure, i do have all expected output (reset of the VLAN & VTP configuration) but still no way to copy the file.
I will keep you informed, regards
amikat Tue, 01/03/2012 - 02:18
What is you vtp status? I would suggest to set it to "client" before deleting the vlan.dat.
Best regards,
Antonin
FlorianBerthelot Fri, 01/06/2012 - 07:42
I tried to change the vtp status, no chance. I did upgrade the chassis to the same version as the originate vlan.dat, and that worked fine.
According to the TAC, this is not a software version issue, bug this might be bug
CSCsj71192.
VSL : Unable to replace vlan.dat file with Sierra image.
Symptom:
Conditions:
When attempting to copy vlan.dat file from disk0: to nvram: the copy is blocked and the console displays the error message "Cannot copy from vlan.dat to vlan.dat"
Workaround:
Downgrade to 12.2(18)SXF7 or upgrade to a release that integrates the fix.
