Can a T1/fractional T1 WIC be configured to work with a 56/64k circuit
May 23rd, 2008
I have a WIC 1DSU T1 and would like to channel it down to a 56/64k to work on a 56/64k circuit provided by the Telco. Can this be done?
Overall Rating: 4.5 (2 ratings)
paolo bevilacqua Fri, 05/23/2008 - 08:17
  • Hall of Fame,
    Founding Member
Yes. Configure the timeslots options under interface, service-module.
colbcisco Fri, 05/23/2008 - 08:26
Would that be:
sevice-module t1 timeslots 1 speed 64
Do you have to worry about the different pinning between a T1 and a 56/64k circuit?
paolo bevilacqua Fri, 05/23/2008 - 08:32
  • Hall of Fame,
    Founding Member
ASAIK, 56K service are really no more. Just ask SP explicitly.
Note make sure to ascertain if circuit is T1 w/ 1 timeslot, or an old and tired 64 kbps circuit. The two things requires different hardware.
Dale McShane Fri, 05/23/2008 - 09:26
It sounds like you have a 56/64K DDS circuit. Your WIC 1DSU T1 will not work with this. You will need a "WIC-1DSU-56K4" card to work with this circuit. A DDS circuit uses pins 1,2,7,8 on the RJ45. A T1 circuit uses pins 1,2,4,5.
Richard Burts Fri, 05/23/2008 - 11:19
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
I ran into this recently at a customer site, where they do have active 56K DDS circuits. And while you can logically specify timeslots down to a single channel and set the speed to 56, the WIC 1DSU will not work on that circuit. You do need the 56K specific card.
Rick
