SDM does not run
May 23rd, 2008
I am trying to run SDM on my XP Workstation. The following is installed:
SDM 2.5
Java 1.6.0_06-b02
When I launch SDM I get the following:
Browser: IE 7.0
Java: Enabled
Then I get a popup window with a bunch of Java code:
(partial copy of code)
* runAPP.shtml
* Copyright (c) 2004 by Cisco Systems, Inc. All rights reserved.
<HTML>
<HEAD>
<script language="javascript" src="common.js"></script>
<script language="javascript" src="appsupport.js"></script>
<script language="javascript" src="localized_msgs6.js"></script>
<script language="javascript">
function getcookie(cookiename) {
var cookiestring=""+document.cookie;
var index1=cookiestring.indexOf(cookiename)
if (index1==-1 || cookiename=="") {
return "";
var index2=cookiestring.indexOf(';',index1);
if (index2==-1) index2=cookiestring.length;
var c = unescape(cookiestring.substring(index1+cookiename.length+1,index2));
return c;
} // getcookie()
function cookieLifeTime() {
var UTCstring;
Today = new Date();
nomilli=Date.parse(Today);
Today.setTime(nomilli+365*24*60*60*1000);
UTCstring = Today.toUTCString();
return UTCstring;
} // cookieLifeTime()
function setcookie(name, value) {
cookiestring=name+"="+value+";EXPIRES="+cookieLifeTime()+";path=/";
document.cookie=cookiestring;
return getcookie(name);
} // setcookie()
function docRoot() {
var args = location.search;
if (args && args.indexOf("SDMONPC=") != -1) {
var curLoc = location.protocol + "//" + location.host + location.pathname;
var i = curLoc.lastIndexOf('/');
var j = curLoc.lastIndexOf('\\');
if ((i == -1) || (i < j)) i = j;
var curBase = unescape(curLoc.substring(0, i));
i = curBase.lastIndexOf('/');
j = curBase.lastIndexOf('\\');
var curBase = curBase.substring(0, i);
curBase = curBase.substring(0, i + 1);
return curBase;
What do I need to do?
sirdudesly Sat, 05/24/2008 - 18:03
I think that if you just tap f5 that window will refresh and give you the security prompt, confirm it and off you go.
