3750 questions
May 23rd, 2008
Hi I am still getting familiar with Cisco products
Can I put a Fiber Optic MM cable into a 24-port 3750 switch? Also if I want to gang 2 3750s together (48-port) what is the best way to do this?
Overall Rating: 5 (1 ratings)
ralphcarter Fri, 05/23/2008 - 12:41
You need a 3750 switch with SFP Ports for the fiber.
Multimode cable uses SX, you need: 1000BaseSX SFP Model: GLC-SX-MM for the 3750 switch with SFP ports
To connect the switches in the best way possible, use the Stackwise Cable. Connect both stack ports to both switches for full duplex operation.
