Licensing info on CRS 3.5 Express
Answered Question
May 23rd, 2008
Hi All,
Where do I look in CRS 3.5 express for the number of agents/supervisor licensing information? We are in the process of updating the total number of users for an possible upgrade to CRS 5.0.
Correct Answer by mudassar.khalid about 8 years 11 months ago
The License test program, ChkLicenseValue.exe, is used to view information
about the license files.
Using the Test Program
Double click the executable, ChkLicenseValue.exe (located in the …DESKTOP_
CFG\Util folder) to open a command window. The command window displays the
a lot of information about your existing license.
mudasar
Correct Answer by Jonathan Schulenberg about 8 years 11 months ago
I believe it is in CRS Administration under System > Licensing. I do not have a 3.5 system in front of me at the moment so that might not be dead on.
The main thing to understand when moving from 3.x to 5.x is that the licensing model has changed. Agents, supervisors and historical reporting each consume generic seats now; they are no longer licensed seperately. Make sure you get an upgrade license key equal the sum of your agents, supervisors, and reporting licenses in 3.5.
Lastly, the Advanced IVR Port Option which you seperately purchased in 3.x determines which edition of UCCX 5 you get: Enhanced (ENH) or Premium (PRE). The entitlement tool doesn't always figure this out correctly so be careful you get the right one. If you had purchased the Advanced IVR Port Option you should be getting UCCX 5 Premium!
Overall Rating: 4 (2 ratings)
Correct Answer
Jonathan Schulenberg Sat, 05/24/2008 - 08:05
  • Cisco Designated VIP,
    2017 IP Telephony
Correct Answer
mudassar.khalid Sun, 05/25/2008 - 08:42
mudasar
