1811 usb ports
May 23rd, 2008
Hi all, Has anyone successfully used their usb ports on their router to connect to the WAN using an aircard?
I'm looking for a cellular option to provide WAN connectivity to a branch location in a remote area.
Any ideas?
paolo bevilacqua Fri, 05/23/2008 - 11:06
  • Hall of Fame,
    Founding Member
Hi, you cannot use the USB ports for anything else than a memory stick.
For wireless access you can use a 1841 plus the wireless 3G HWIC, or onw of the new 88xG that does what you're asking for.
