Unity login via DID
Answered Question
May 23rd, 2008
I have a client with about 40 users on a UCM6.0 Business Edition system running Unity Connection 2.0. They each have a DID. When they call their DID and it rings to voicemail, is it possible so that when they press *, Unity will only prompt them for a password, not an ID AND a password?
Correct Answer by ranpierce about 8 years 11 months ago
might be,
try going to Subscibers\Caller Input in the Unity admin and changing the * to easy sign in.
hope this helps
Randy
Overall Rating: 5 (1 ratings)
Correct Answer
ranpierce Fri, 05/23/2008 - 11:29
  • Silver, 250 points or more
might be,
hope this helps
Randy
Chris Driggers Fri, 05/23/2008 - 11:35
That's exactly right. I ended up just adding option 1 for easy sign on and leaving * as the regular sign on.
ranpierce Fri, 05/23/2008 - 11:42
might be,
hope this helps
Randy
