MARS Upgrade Path
May 23rd, 2008
I have a MARS 20 version 4.2.3(2403). I'd like to upgrade to the latest which I believe is 4.3.4.2804. Is it accurate that I need to step through each interim upgrade between the two to acheive my goal ?
TIA
pmccubbin Mon, 05/26/2008 - 03:02
Hi Dave,
Yes, the "bunny steps" approach is the one you must employ if you want to keep your configuration and all the events. Otherwise, use an ISO image and go directly to the latest image.
Hope this helps.
Paul
