Another Baseline Question - interfaces
Answered Question
I'm trying to create a template that checks all 48 fa ports to ensure they have port security, are in access mode, portfast etc. I don't think i can do this with a basic template and can't figure out how in a basic template. Anyone done this before? If so, perhaps you could even attach the xml so i can see how it works.
TIA
Correct Answer by Joe Clarke about 8 years 9 months ago
Here it is inline:
<?xml version="1.0" encoding="UTF-8"?>
switchport mode access spanning-tree portfast switchport port-securityinterface [#FastEthernet.*#]
Overall Rating: 5 (1 ratings)
Joe Clarke Fri, 05/23/2008 - 12:08
Exactly what version of RME are you using? This is very easy to do using an advanced template assuming ALL 48 ports need to be checked for the same commands.
Correct Answer
Joe Clarke Tue, 05/27/2008 - 10:05
Here it is inline:
