E1 aggregation
May 23rd, 2008
Dear all
I have about 50 E1 to my distribute point.
what device could handle this number of e1?
Overall Rating: 4 (1 ratings)
Paolo Bevilacqua Fri, 05/23/2008 - 12:06
A 7206 can have 48 x E1. Biggewr router, a lot more. However if you intend to bundle them together as a single high speed circuit, that would be a poor design and you should avoid.
miskoolak Fri, 05/23/2008 - 12:58
it has E1 pri-cas.. interface module..i think we can use it just without DSP.
miskoolak Sat, 05/24/2008 - 08:17
they are just for data transportaion.
I know that AS5850 are used for Ip telephony but because of price fee i want to use as5850 E1 modules just for data transport.
I think this is like when you use VWIC for data transport.
Paolo Bevilacqua Sat, 05/24/2008 - 08:21
No, as I said before the 5850 will not work for this.
You need a class 7200 router or better, with the 8 ports card. You can also ask your telco if they can deliver the E1 within a channelized E3 or STM-1. This will allow you using one or two interfaces in total.
