Need configuration assistance on Cisco ASA 5510 please
May 23rd, 2008
first time ocnfiguring ASA. I have configure two ASA devices, Promary and secondar and the failover seem to be working but I have routing issues in which I cannot reach devices behind the ASA.
both Inside and Outside Interfaces have Public IP addreses and customer doesn't want NAT. I have added static router inside to the inside block gateway IP which is on the core router. and also static outside 0/0 outside interface.
I havenot done any translation and think that might have contributed to this problem but wanted to see if I need to create a global outside interface since i have no NAT?
husycisco Sat, 05/24/2008 - 06:31
Hi Masood
If customer doenst want NAT, simply issue "no nat-control" in firewalls and do not spend time on exempt nat statements
m-abooali Sat, 05/24/2008 - 09:11
Hi and thanks for your input.
The problem was due to the stupid "no proxy Arp" on the inside Interface!
that was scrwing up all the routing that I had in there. so upon disabling the proxy Arp on the inside interface all the servers behind the firewall were able to hit th eInternet!
