Install ACE20-MOD-K9 in 6513
May 24th, 2008
Hi all,
I want to install ACE20-MOD-K9 in 6513 Switch ,I install module in slot 5 and all other modules except supervisory engine get blocked ,Does anyone knows in which slot ACE20-MOD-K9 to be installed in 6513 Switch
Sudeesh
Edison Ortiz Sat, 05/24/2008 - 07:45
It should be fine in that slot. The behavior you've mentioned sounds like you surpassed the power limitation in the box.
I highly recommend checking the power calculator website and see if your power supplies can meet your need http://www.cisco.com/go/powercalculator
HTH,
__
Edison.
