WAAS in PBR mode and multi path load balancing
May 24th, 2008
Do WAAS 4.0.17 support per packet multi path load balancing trought tow gateway ? and how we can configure it?
NB. Adding tow route with the same distance doesn't operate as load balance solution.
Best Regards,
Ahmed
Mohamed Anees M... Tue, 05/27/2008 - 07:23
  • Bronze, 100 points or more
I don't see any features in WAAS that does per packet load balancing. can you try configuring GLBP for the WAE default gateway and achieve load balancing?
