FXO to IPphone
May 24th, 2008
Dear all
i Have fxo port on my voice gateway
i define connection plar on my FXO voice-port.and also defined sutable dial-peer to route the connection plar into CCM.
but when I dial the number i hear just fastbusy!
i debuged and saw theat the connection plar and dial-peer matches.
any idea?
Paolo Bevilacqua Sat, 05/24/2008 - 09:52
First of all plar opx is always better than just plar.
Then chances are the CCM refuses the call, do you have codec g711u and no var under DP ?
miskoolak Sat, 05/24/2008 - 10:10
yes both no vad and codec g711u is under dial-peer
but still ccm reject the call and i have fastbusy signal
Kapil Atrish Sun, 05/25/2008 - 10:54
I am sure you have set significant digits, incoming CSS on GW correctly and destination-phone is registered to ccm. If not ideally you should get error-message from CCM rather then fast busy tone, but you've not specified CCM Version and there are bugs in CCM 5.0 which prevents message from CCM so I thougt of mentioning it.
If possible share debug voice ccapi inout.
