Catalyst 2924 VLAN/VTP
May 24th, 2008
Does a catalyst switch running ios version 12.0(5) support running a vtp domain configuration. Where vtp clients receive updates from the vtp server? If so can someone help me with the Syntax?
Thank you,
David
Overall Rating: 5 (1 ratings)
davidschuetz Sun, 05/25/2008 - 10:14
Thanks to everyone for the responses! I think this article had the most information though. My problem was I was trying to find the configuration and syntax from global configuration mode. Thanks for the info jorgemcse.
David
Giuseppe Larosa Sun, 05/25/2008 - 03:55
  • Hall of Fame,
    Founding Member
take care of the different limit in the number of vlans supported that exist on different platforms.
If your c2924 can support only 128 vlans (for example) and more vlans exist in your vtp domain the c2924 will automatically changes its mode to vtp transparent to protect itself.
I've experienced this problem some years ago.
hope to help
Giuseppe
jahilnt10 Sun, 05/25/2008 - 04:33
Well,
To get the advantages of VTP you need to have one switch acting as VTP server.
lets say, you got two switch A and B.
lets make Switch A as VTP server and select domain name for the VTP.
Swtich-A(config)# vtp mode server
Swtich-A(config)# vtp domain jahil
You can create vlans on server A those you want to replicate with rest of the domain.
On switch B you have to configure vtp mode. If you want to replicate you need to set vtp mode CLIENT or SERVER. If you don't want to participate in VTP domain set it to transparent.
