How to increase output queue-limit more than 4096 on Giga int ?
May 24th, 2008
I am using Cisco 10k router (Cisco C10008 (PRE2-RP)), IOS : "c10k2-p11-mz.122-27.SBB4" & "c10k2-p11-mz.122-28.SB8".
I have some Giga interfaces with max hold-queue limit 4096.
Due to some customer requirement, I need to increase output queue-limit from more than 4096, which is a max value Giga int take.
Is there any way to increase the queue-limit for Giga interface?
paolo bevilacqua Sat, 05/24/2008 - 16:17
  • Hall of Fame,
    Founding Member
What would be the customer requirement ? Because what you want to do doesn't make sense at all.
ashish-nagpal Sat, 05/24/2008 - 16:28
I know this much information may not make sense, but the thing is, this all was working fine with ATM link but Gagalink.
I am running multiple traffic classes with varying queue-limit in each class and due to huge b/w of link, queue-limit required is more than 4096 packets in each class.
The error I am getting is as follow:
router(config-subif)#service-policy output cos-out
Queue-limit 16384 not supported on GigabitEthernet1/1/1.1, overridden to 4096
Queue-limit 32768 not supported on GigabitEthernet1/1/1.1, overridden to 4096
Queue-limit 8192 not supported on GigabitEthernet1/1/1.1, overridden to 4096
paolo bevilacqua Sat, 05/24/2008 - 16:35
  • Hall of Fame,
    Founding Member
Can you post the service policy? I'm unsure of what they're trying to do in practice.
ashish-nagpal Sun, 05/25/2008 - 01:40
Here is the config:
policy-map cos_police
class voice
priority
police percent 30 2 ms 0 ms conform-action transmit exceed-action drop violate-action drop
queue-limit 16384
class data1
bandwidth remaining percent 13
queue-limit 32768
class class-default
bandwidth remaining percent 87
queue-limit 8192
policy-map cos_out
class class-default
shape 600000
service-policy cos_police
interface GigabitEthernet1/1/1.1
description - BW=450
encapsulation dot1Q 90
ip address 10.0.0.1 255.255.255.252
service-policy output cos_out
What basically I need is to know,if there is any way to increase the Giga interface output queue-limit from 4096 ?
paolo bevilacqua Sun, 05/25/2008 - 03:24
  • Hall of Fame,
    Founding Member
There is no way. Beside, with the low speed shaping, the queue limits are too large and would not apply. Verify first how things work without any queue-limit that are not recommended by cisco.
Note for the voice class, you if you enter values for the priority statement, policing is not necessary.
ashish-nagpal Sun, 05/25/2008 - 09:40
It is 10k router. There is no option to put any value after priority statement in voice class here and even cisco says to use "police" when no value(percentage/bytes) can be given for priority statement as it works in the same way.
Thanks for even considering my query but can I have a logical reason that why am I not able to increase queue-limit in case of giga interface, whereas ATM has automatically manipulated itself with higher queue-limit?
paolo bevilacqua Sun, 05/25/2008 - 11:07
  • Hall of Fame,
    Founding Member
Hi, I wasn't aware of the priority commands limitation for your case.
Different hardware has different drivers and logic. The gigabit being a musch faster interface allows only smaller queues to be built. In fact, the shaping you're doing on is already a artifice, as the QoS should be applied to the real point of congestion.
If sharing the bandwidth is the only goal, it should not much difference what is the queue limit. After all, is not that queued traffic can be kept to huge amounts, it must be dropped at some point.
ashish-nagpal Sun, 05/25/2008 - 23:11
I agree with you. B/W ATM interface having was 45MB and throughput was not higher than it. now I have increased link b/w in a huge proportion but perhaps some day requirement is increased then again I would think about this limit though I know large queue will increase delay and require more buffering and processing power. But you know customers, they will point queue-limit again. :)
nstathak Sun, 05/25/2008 - 22:09
why do the need greater 4096 especially on a GE interface. I do see the config from the ATM interface, different type of card which is made to buffer and the GE max is 4096 never seen it bigger than that.
ashish-nagpal Sun, 05/25/2008 - 23:16
I don't require in particular actually. It is just that earlier ATM interface had higher queue limit with lesser access-link b/w but if I change the limit to lesser one now, customer would keep on asking that why it's been changed without understanding the nature of interface and link. :)
