05-24-2008 04:53 PM - edited 03-15-2019 10:51 AM
I will have a Callmanager 6.1(1) voice gateway connecting to two traditional PBXs over E1s using MGCP. One of the E1 will be configured as QSIG, and the other one as Net-5. Is this possible? What switch type will I configure on the global configuration?
05-24-2008 05:09 PM
Yes, it's possible. CCM supports both switch types.
05-24-2008 05:19 PM
Thanks for the response.
As the single gateway will be connecting to two PABXs, each with different protocol type, QSIG and Net-5.
Which protocol type do I configure on the global config, QSIG or Net-5?
I assume that I would be able to configure the first E1 as QSIG and the other E1 as Net-5 on the Callamanager 6.1?
05-25-2008 10:42 AM
CCM provides only global config for ISDN Switch type. You need to specify different switch-type on both isdn interfaces on the router manually which will override the global switch-type configuration pushed by the ccm to gw.
thanks,
inner_silence
05-25-2008 10:44 AM
Hi, with MGCP the switch type configured on the GW doesn't matter, you configure the proper type in the CCM.
05-31-2008 10:15 AM
In case different switch-types are required on same MGCP GW, we can configure no ccm-config and configure different switch-types on idn interfaces manually.
inner_silence
05-31-2008 01:29 PM
With MGCP, it doesn't matter what switchtype is configured. All is controlled by the sofwswitch.
In reality, being qsig a pri derivate (net5 being the reference), it really doesn't matter what is set, as long CCM know how to use specific qsig stuff that can be present on a circuit but not on the other.
