Initial Router Config. IP addresses
May 24th, 2008
How can I get the Inside and Outside Global IP's when configuring my 871 Ethernet Wideband Router? The ISP doesn't provide them.
Richard Burts Sat, 05/24/2008 - 17:21
Larry
I think that I do not understand the part of your question about global inside address. The inside address is generally dependent on the design and implementation of your network. Perhaps you can clarify this?
I also do not understand the part of your question about the global outside address. Is the router connected to a Service Provider? If so the SP generally provides either a static address and dynamically assigns an address for the outside interface. Perhaps you can clarify what your environment and topology are?
Rick
sirdudesly Sat, 05/24/2008 - 17:59
The inside IP isn't provided by your ISP because it's exactly that, it's "inside" your network.
