Remote VPN Users unable to access Local LAN
May 24th, 2008
I just replaced my PIX501 with an ASA5505. I'm not real familiar with Cisco Products, but I'm comfortable with it. I'm attaching my config list. I can connect to the VPN just fine, but I can't ping or connect to anything on the Local LAN. I really appreciate the help!!!
Anonymous (not verified) Tue, 06/03/2008 - 11:30
JORGE RODRIGUEZ Tue, 06/03/2008 - 19:50
  • Green, 3000 points or more
change your access list to allow VPN IP pool network to inside 192.168.1.0 network
your inside network is 192.168.1.0/24 , your vpn local pool network is 192.168.2.0/24
remove
no access-list inside_nat0_outbound extended permit ip any 192.168.2.96 255.255.255.224
no access-list inside_nat0_outbound extended permit ip any 192.168.2.0 255.255.255.0
replace with
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 192.168.2.0 255.255.255.0
try connecting and access inside hosts from vpn client and let me know the results.
Rgds
-Jorge
