remote access vpn problem
May 24th, 2008
Dear Pros,
Please find below the problem i am facing in one of my project.
The inside network 192.168.1.0/24,
after the remote vpn client conected he can not access the exchange server in this network with ip 192.168.1.2. The user telling that the remote PC also in 192.168.1.0/24 that is assigned by adsl ISP provided modem.
Due to that the customer asking to change the internal LAN IP from 192.168.1.0 to 172.16.0.0 range.
Is there any way to correct this issue without changeing the IP structure.
swami
arumugasamy Tue, 05/27/2008 - 00:29
Andrew,
Thanks for your help.
split tunnel is not on.
the remote user pool is 11.0.0.0/24.
Whenever the customer using coffee shop internet connection, they getting the problem.
swami
michael.leblanc Mon, 05/26/2008 - 16:22
  • Silver, 250 points or more
If you look at the Transport tab of the Connection Properties (Cisco VPN Client), you will see a checkbox for a feature called "Allow Local LAN Access".
I believe:
If you de-select this, packets sent to 192.168.1.x addresses will go through the VPN tunnel when the tunnel is up, and to the local network when the tunnel is down.
