ICM Installation
May 25th, 2008
Can I install a sprawler with only "read-only" access provided by the domain controller? Do we need admin rights for the installation.
david.macias Sun, 05/25/2008 - 04:59
Not sure what you mean by read only mode. However, you will need local admin rights on the pc in order to install the ICM components. You'll also have to have a AD admin set up the ICM OU for you.
rbua Sun, 05/25/2008 - 23:09
Hi Jayadev,
the answer is no. ICM uses the installer rights to create accounts and join the domain and create the SQL Server users Domain Admin or OU admin rights are needed to perform the setup.
