Web VPN Applet Window size increase
May 25th, 2008
I have configured ASA for Cisco Anyconnect SSL Client and Cisco Secure Desktop. When the user does SSH a new window or applet appears and i am able to do ssh properly.
the applet or window size where ssh is appearing, is very small. i need to increase the size of applet window. How can i do that.
Overall Rating: 5 (1 ratings)
talha_490 Sun, 06/01/2008 - 01:13
Dear smalkeric,
the ssl vpn is working fine but after that i need to ssh a server which i am doing through the web VPN screen. the problem is the applet window size is small i need to enlarge it
Farrukh Haroon Fri, 06/06/2008 - 06:15
  • Red, 2250 points or more
There might be a solution to your problem, but don't do this on a production ASA :). Also this might be a configuration not supported by Cisco TAC.
There is a file in the ssh-plugin.jar root called "conf.conf". Open the jar with winrar and edit this file to add these two lines:
Applet.disconnect = false (Already there)
Applet.detach = true
Applet.detach.fullscreen = true
But please be careful with this :)
Farrukh
Farrukh Haroon Fri, 06/06/2008 - 06:42
Also you could try one more thing:
In the following location you will find a 'jta.html' file,
disk0:/csco_config/97/plugin/ssh
There you could try to edit the following line:
< applet id=tty codebase=\".\" archive=jta26.jar code=de.mud.jta.Applet width=590 height=360> < param name=Socket.host value=" + server + "> < param name=Socket.port value=" + port + ">
And change the height and width parameters to something larger:
Farrukh
wantechdean Fri, 11/06/2009 - 07:10
I was able to increase the telnet window size to 1024x768. The window is now perfect. Thanks for this post.
Farrukh Haroon Fri, 11/06/2009 - 09:31
I'm glad I could help.
First solution worked or the second one? :)
Farrukh
wantechdean Fri, 11/06/2009 - 09:49
I did this one....
[QUOTE]
Farrukh
[/QUOTE]
Thanks again.
cmaysonet Wed, 09/01/2010 - 07:54
How do i get to dis folder?
I cannot find it in File Managment
