IPsec VPN Client Auto-Update Feature
Answered Question
May 25th, 2008
Hello.
Did someone ever try the PIX/ASA "IPsec VPN Client Auto-Update Feature" ?
(see also Document ID: 105606).
It just want to make sure I understand this right.
The user will get an information popup which tells him to download the latest client? And then he has to start the update himself?
If yes, this would mean the user has to have full adminsitative rights on his laptop.
From my point of view, full admin rights on a laptop are a 100% no-go - and so the feature would be totally useless.
Anyone who can tell me if I'm right or wrong?
Best
Frank
Correct Answer by JORGE RODRIGUEZ about 8 years 10 months ago
Frank,
You are correct, if the desktop or labtop is completely locked in terms of installing software the client will not be able to install it, they may be able to download from the link you have configured in ASA once they connect to your RA ASA server but as far as installing it user's machine needs appropriate profile rights to be able to install it.
-Jorge
Overall Rating: 5 (1 ratings)
Correct Answer
JORGE RODRIGUEZ Sun, 05/25/2008 - 09:21
  • Green, 3000 points or more
Frank,
-Jorge
fherlan Sun, 05/25/2008 - 23:29
Hello Jorge.
Thanks a lot.
In this case I consider the feature -> useless.
Best regards
Frank
