CiscoWorks - Check for a certain command
Answered Question
May 25th, 2008
Is there a way to check the running config of a whole heap of devices for a certain command?
Login to every device and check for say this text....ip http server
Then in the results it would show me which ones have it and which ones don't
Correct Answer by David Stanford about 8 years 8 months ago
You can use baseline templates in RME to do this
Overall Rating: 5 (1 ratings)
