Command Accounting Failure on my PIX
Answered Question
May 25th, 2008
I am configuring my PIX ver 7.2(2) for command accounting using the "aaa accounting command" command but I am not able to see any accounting information on my ACS 4.1 build 23 server!
Although authentication for this PIX is working just fine and the accounting is also working perfectly for other IOS devices, accounting for the PIX is not giving any results when browsing to the TACACS+ administration page!!
I am posting the PIX show-tech for your referecne!
Appreciate your support here!
BR,
Haitham
Correct Answer by rochopra about 8 years 9 months ago
Would recomend you to have a look at this bug CSCsg97429.
~Rohit
Overall Rating: 5 (1 ratings)
haithamnofal Tue, 05/27/2008 - 10:36
Hi Rohit,
Thank you so much, you were absolutely right. The accounting problem was due to the bug CSCsg97429 and the problem was resolved after applying the patch: applAcs-4.1.1.23.1.zip
Haitham
