Command Accounting Failure on PIX
May 25th, 2008
I am configuring my PIX ver 7.2(2) for command accounting using the "aaa accounting command" command but I am not able to see any accounting information on my ACS 4.1 build 23 server!
Although authentication for this PIX is working just fine and the accounting is also working perfectly for other IOS devices, accounting for the PIX is not giving any results when browsing to the TACACS+ administration page!!
I am posting the PIX show-tech for your referecne!
Appreciate your support here!
BR,
Haitham
vitripat Sun, 05/25/2008 - 17:17
What commands are you unable to see? As per your configuration, all commands except show commands will be logged.
"When you configure the aaa accounting command command, each command other than show commands entered by an administrator is recorded and sent to the accounting server or servers."
http://www.cisco.com/en/US/docs/security/asa/asa72/command/reference/a1_72.html#wp1437180
Are you able to see other commands?
Vibhor.
