Question about the command to force the standby CSM to be active
Answered Question
May 25th, 2008
  • Bronze, 100 points or more
Hi everyone,
Is there any command to force the standby CSM (Content Switching Module on Catalyst 6500) to be active ?
such as "redundancy force-master" command on CSS.
I can not find such command on CCO.
Your information would be appreciated.
Correct Answer by Syed Iftekhar Ahmed about 9 years 1 day ago
clear module csm x ft active
(make sure peremption is disabled befor you run this command).
Syed
Overall Rating: 5 (1 ratings)
Correct Answer
Syed Iftekhar Ahmed Tue, 05/27/2008 - 13:23
  • Blue, 1500 points or more
Syed
snakayama Tue, 05/27/2008 - 20:16
Syed,
Thank you very much for your reply.
Shinichi
