VWIC-2MFT-E1 card on c3825 router
May 25th, 2008
I want to install VWIC card on c3825 router. When I plug VWIC card in c3825 I got following error on my screen.
*May 26 11:48:55.031: %ESWMRVL_FLTMG-5-NOTICE: Notice: FPGA Rev 0x71
*May 26 11:48:55.431: %E1T1_MODULE-3-INITFAILURE: Slot 0, Unit 3 initialization failure - Firmware Download
*May 26 11:48:55.431: %E1T1_MODULE-3-INITFAILURE: Slot 0, Unit 3 initialization failure - FPGA & Firmware Download
How to recognize that card on the router?
Thank you
Best regards,
Tseveen.
paolo bevilacqua Mon, 05/26/2008 - 00:31
  • Hall of Fame,
    Founding Member
That should not happen. By the way, are you inserting the card with the router turned on? Because that is not supported.
