Login Problem
Answered Question
May 25th, 2008
Dear seniors,
We are not able to access the Router (7206VXR) on today day before yesterday we were work on that we were accessing the router through putty because telnet is disable on router and Network Error Connection Refused. This error we are getting while accessing the router remotely…so what could be the problem how I can resolve this issue
Correct Answer by guruprasadr about 8 years 7 months ago
HI Sasi,
As discussed, since the VTY Session are not timed-out configure the VTY Line as below:
line vty 0 4
"exec-timeout 3 0"
The Exec-timeout will help to clear the Lines after certain period of time.
Best Regards,
Guru Prasad R
Overall Rating: 5 (1 ratings)
guruprasadr Sun, 05/25/2008 - 21:47
HI Sasikumar, [Pls Rate if HELPS]
In the Configuartion under "Line VTY" have you done any changes like "transport input none" command
because this command will not allow anyone to login via the VTY Sessions by preventing the Telnet Access on Port 23. Try login via Console and remove such commands if any.
Is the services of the Router are working fine ?
Hope i am informative.
Pls Rate if HELPS
Best Regards,
Guru Prasad R
msasikumar Sun, 05/25/2008 - 22:18
we didn't change any thing on router previos we were logging throug putty only now we not able to access
guruprasadr Sun, 05/25/2008 - 23:16
HI Sasikumar,
Are you able to login via Console and check any un-usual logs regards to authentication via VTY ?
Guru Prasad R
msasikumar Sun, 05/25/2008 - 23:32
yes we access the router through console and we cleared the lines VTY because login 15 was there now we solved this issue
mahmoodmkl Sun, 05/25/2008 - 23:25
U need to use a terminal software which supports SSH try secreCRT.
Mahmood
guruprasadr Sun, 05/25/2008 - 23:35
HI Sasikumar,
Can you paste the line VTY Config and AAA Configuration ?
Guru Prasad R
Correct Answer
guruprasadr Sun, 05/25/2008 - 23:49
HI Sasi,
line vty 0 4
"exec-timeout 3 0"
Best Regards,
Guru Prasad R
