unable to boot to flash
May 25th, 2008
Hi. I am currently using a 2600 series router and after installing a module, the router wouldn't boot the flash and just loops back to rommon. When i remove the said module, the router just boots fine into flash. The module is older than the router and i am thinking that the 2600 should be somewhat backward compatible. Please advise.
Thank you.
sirdudesly Sun, 05/25/2008 - 22:37
What WIC and what rotuer are you trying to use it with (IOS version would help as well)
I'm not sure what a router does if you try and use a card when your IOS doesn't have that feature set.
