want to Connect my router to Internet
May 25th, 2008
Dear All, we have CISCO 3600 series router with 4 ethernet ports . i want to connect Internet with my router and ISP which is currently running at the site is on Dynamic IP. so could u please provide me a Demo Configuration tht how can i connect internet to our router.
mahmoodmkl Sun, 05/25/2008 - 22:51
  • Gold, 750 points or more
I think u can connect the link from u r ISP in one of the ethernet ports as u said that they are providing dynamic IPs u have to configure the port in which u r connecting the ISP link as below.
config t#
.........#interface
........if#ip address dhcp
and u need to configure NAT.
It will be helpful if u give us a overview of u r topology.
Mahmood
atul.trivedi12 Mon, 05/26/2008 - 00:51
First of all thax a lot , i want internet connection for specific users in my organisation and i am using a broadband 256 Kbps DSL line. so i want to terminate tht 256 KBPS DSl line on my router and want to use this for internet connectivity ,
paolo bevilacqua Mon, 05/26/2008 - 01:23
  • Hall of Fame,
    Founding Member
You need a wic-1adsl card. Do you have that ?
Jacob Samuel Mon, 05/26/2008 - 01:34
Both adsl and dsl are using same kind of interfaces? Is adsl is comng with small Pin while dsl like normal RJ 45 type? DSL we can terminate on FE port. But for ADSL you need the WIC ADSL Card.
Please correct me if i am wrong.
regards
atul.trivedi12 Mon, 05/26/2008 - 02:12
Thax for support.i have a DSL to Ethernet converter , by which can i terminate the link on FE. and please suggest me what should i know from Service provider for configuration . is there any information will be required from service provider . or i can implement a normal configuration .
atul.trivedi12 Mon, 05/26/2008 - 02:15
Please suggest me what configuration should be used by me to configure the Interface , i have to configure IP route for the same , or itz not required , now can u please provide me a sample configuration which i can implement on router.
Amit Singh Mon, 05/26/2008 - 02:23
  • Cisco Employee,
Hi Atul,
You first need to determine whether you have to get a dynamic IP from the SP on the router ethernet connection or the static IP. If dynamic than you can use the command pasted above by one of the poster. If static then we have to manually put the IP on the interface.
Then you have to configure NAT on the router to translate all the internal IP to the IP provided by the SP.
Please use the link below for the sample configuration.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094e77.shtml#topic3
HTH,
-amit singh
paolo bevilacqua Mon, 05/26/2008 - 02:27
  • Hall of Fame,
    Founding Member
Hi, best would if you get wic-1dsl card.
If you can't, ask ISP if they are using bridged IP, or PPPoe, or PPPoA. It's easy to tell as these latter come with username/passwrd.
