CiscoWorks - Check for a certain command
Answered Question
May 25th, 2008
Is there a way to check the running config of a whole heap of devices for a certain command?
Login to every device and check for say this text....ip http server
Then in the results it would show me which ones have it and which ones don't
Correct Answer by Joe Clarke about 9 years 2 months ago
You can easily search the RME configuration archive for a pattern (e.g. ip http server). The results will show you all devices which have this pattern in their config.
However, if you want to see devices which have the pattern and those that don't, you're probably better off using RME's Baseline compliance feature.
With baseline compliance, you can create a baseline template with the following command:
+ ip http server
All devices which have this line in their config will be marked compliant. All devices which do not will be marked as non-compliant.
Baseline compliance is available in RME 4.0 and higher. The Search Archive By Pattern feature is available in all versions of RME.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Sun, 05/25/2008 - 23:13
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
+ ip http server
