Cisco 877W and QoS Voice
May 25th, 2008
Hello all. I have a Cisco Router 877W. In the Site '' it is written that it supports the QoS voice. But in the router management it is not found. Why?
Alex Pfeil Wed, 05/28/2008 - 06:30
I believe that you have to configure it from the Command Line Interface.
The 877W does not have the ability to do trust, so if you wanted to do QOS across ports I told someone in another forum to try this. I have not heard back, but I think it should work.
!match traffic
access-list 101 permit tcp any any eq 110
access-list 101 permit tcp any any eq 25
access-list 101 permit tcp any any eq 80
class-map match-any high-priority-class
match access-group 101
policy-map high-priority-policy
class high-priority-class
set ip dscp af31
!apply to interface
interface faxx
service-policy output high-priority-policy
!Using the MQC:
> Router(config)#class-map HIGHPRIORITY
> match http
> match pop3
> match smtp
> bandwidth X
> X = the total % or in kbs of the bandwidth you want to allow for your
> traffic.
> then, just go under the WAN interface and do:
> Router(config-if)#service-policy output HIGHPRIORITY_POLICY
That should take care of it. That will give priority to traffic going
outbound on your WAN interface. If you have services hosted within your network, then you would change that to inbound.
Royce Lindsey, CCVP
seclab007 Fri, 05/30/2008 - 03:50
thanks for this reply, but i need prority traffic on RTP.
Say me if this config is good or not for my problem.
Thanks in advance.
I wait your reply
