ASDM for PIX 722
Answered Question
May 25th, 2008
Hi Guys,
Im planning to install asdm on my newly upgrade PIX 525 ve722. I just want to know if i need to install the asdm on my failover pix. Is there any problem if i just install it in one of my pix (active) only? What is the most stable asdm image for my pix?
Jong
Correct Answer by JORGE RODRIGUEZ about 8 years 8 months ago
Jong,
The most stable asdm version for your running PIX code 7.2.2 is asdm version 5.2.2, image file name asdm-522.bin.
Yes, you do need asdm installed in your failover, asdm is not required for firewall functionality unless you are %100 confortable dealing with command line. Personally I would also install asdm in failover to be consistant with your active unit.
-Jorge
Overall Rating: 5 (1 ratings)
Correct Answer
JORGE RODRIGUEZ Mon, 05/26/2008 - 00:15
Jong,
-Jorge
