Question about the lithium battery on MSFC
Answered Question
May 25th, 2008
Hi everyone,
I have the question about the lithium battery on MSFC.
Is there any command to display voltage of lithium battery to confirm whether the life of lithium battery is lost.
I can not find related information on CCO.
Your information would be appreciated.
Correct Answer by irisrios about 8 years 9 months ago
To monitor the voltage or health of the battery, I have not seen any CLI command that displays information on the battery status.
There is a simple battery check built into the NVRAM component. When there is a drop in the battery voltage, the NVRAM generates a 'battery low' signal. This is used to notify SW of this condition. SW then generates the 'NVRAM low battery' error message. Since the battery is entirely enclosed within the NVRAM component, there is no other way to monitor battery health in a more direct manner.
Overall Rating: 5 (1 ratings)
Correct Answer
irisrios Fri, 05/30/2008 - 06:39
snakayama Sun, 06/01/2008 - 17:21
Thank you very much for your reply.
I understand it.
