lpezj Mon, 05/26/2008 - 00:57
  • Gold, 750 points or more
I think that UCCX can only be integrated with one Callmanager cluster. It is likely that you can set up agents is one cluster and send calls to/from one cluster to another, but all the agents must be in the same cluster.
You can use two UCCX, one for each cluster, and use IPCC Enterprise to load balance between the UCCX agents in each cluster.
You can too use only IPCC Enterprise with one PG for each cluster to load balance or distribute calls among the two CallManager clusters.
Hope this helps,
Juan Luis
Riccardo Bua Mon, 05/26/2008 - 04:54
  • Cisco Employee,
you will need to define an application and profile on each cluster, there is no mean to load balance across clusters or applications, so agents will need to be used by one or the other, licenses will be the ones in use, you might eventually spare some hardware, but the overall administration will be quite cumbersome to say the least(make scripts twice and so on...).
Using UCCE you might be able to balance the load across ipccx and clusters as Juan Luis was rightfully suggesting.
Riccardo
Chris Deren Mon, 05/26/2008 - 08:13
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
ONLY ONE cluster, as you can only point one CM at a time via AXL on UCCX 4.5/5.0 or directory on 4.0 and earier. So, if you need to point to another cluster you will need to recreate the integraion.
You can point multiple UCCX environments to a single CM cluster.
Chris
agtmcgarry Thu, 06/26/2008 - 01:46
I have
UCCE7.2.4
CVP4.1
UCM6.1
I have two callmanager clusters.
I created a generic pg and configured both callmanager clusters and cvp as pims 1,2,3
All pims went active and all looked good.
However I found that I could only logon to the first callmanager. On the jgw process I could see the logon request to a device on the second callmanager cluster going to the first cluster jgw process and CTIOS logon failing.
Do you know a way of specifying the second callmanager cluster.
I also tried creating a second pg. So I deleted the second callmanager pim from the first pg, updated the routers for 2 pgs and installed a second generic pg with one callmanager pim.
Now both my jgw processes keep crashing and neither callmanager goes active.
Any help would be much appreciated.
Anthony
Riccardo Bua Thu, 06/26/2008 - 01:51
  • Cisco Employee,
Hi Anthony are you using the same application, JTAPI user and call searching space or different ones?
agtmcgarry Thu, 06/26/2008 - 02:02
I have two seperate UCM clusters, both 6.1. I have two PG's with ICM7.2.4 and CTIOS7.2.4. Each cluster has an ipcc pg user configured.
They both use the same username.
Riccardo Bua Thu, 06/26/2008 - 02:03
  • Cisco Employee,
Hi Anthony,
please try using a different username and let me know if the issue persist.
Riccardo
Chad Stachowicz Sun, 06/29/2008 - 22:09
  • Silver, 250 points or more
In my travels and my opinion. Each CTIOS instance must be the SAME PID as its associated agent PG, and if its not login's will not work. Therefore useing this same logic, each agent PG to each cluster need its own instance of CTIOS. And you then need to login to the correct CTIOS instance. This is the reason you are always seeing it try the first cluster! Just my 2 Cents.
Chad
agtmcgarry Mon, 06/30/2008 - 06:42
Hi Chad,
Yes in the CTIOS setup you have to select the PID of the ACD. Therefore in my setup with a side A and B CTIOS both where using the PID from UCM cluster 1. Therefore all requests where going only to the first cluster.
A workaround for now was to break the side A/B and have CTIOS and PG's in simplex. One for each cluster.
Anthony
