how to clear controller output error?
May 26th, 2008
Hi All,
could you please advise how to clear 'show controller' output error? example as below:
INASAA601#sh controll atm1/0 | i error
RSM ignore rbd unknown count 0, pdu_check flag 0x0, error flag 0x0
DS3: F/M-bit errors 15900352
DS3: parity errors 100694648
DS3: path parity errors 69221054
DS3/E3: G.832 FEBE errors 146970865
uncorrectable HEC errors 32395
LCV errored secs 15363
DS3: F/M-bit errored secs 15621
DS3: parity errored secs 15690
DS3: path parity errored secs 15690
T3/E3: excessive zeros errored secs 15363
DS3/E3: G.832 FEBE errored secs 104797
uncorrectable HEC errored secs 309
LCV error-free secs 5456630
DS3: F/M-bit error-free secs 5456372
DS3: parity error-free secs 5456303
DS3: path parity error-free secs 5456303
T3/E3: excessive zeros error-free secs 5456630
DS3/E3: G.832 FEBE error-free secs 5367196
uncorrectable HEC error-free secs 5471684
INASAA601#
INASAA601#cle counter
Clear "show interface" counters on all interfaces [confirm]
INASAA601#
LCV error-free secs 5456682
DS3: F/M-bit error-free secs 5456424
DS3: parity error-free secs 5456355
DS3: path parity error-free secs 5456355
T3/E3: excessive zeros error-free secs 5456682
DS3/E3: G.832 FEBE error-free secs 5367248
uncorrectable HEC error-free secs 5471736
INASAA601#
It seems normal 'clear counter' not able to clear these error. thank you!
Overall Rating: 5 (1 ratings)
Amit Singh Mon, 05/26/2008 - 01:44
  • Cisco Employee,
The command " Clear counters " will only clear the software related counters on the interfaces. This command will not clear the hardware counters.
Depending on the platform used, you can use the command " clear counters controllers " or Clear controllers " commands to work this out. If these commands donot work then you may try reseating the card back in the chassis or reload the router to clear the counters.
HTH,
-amit singh
