ACESM inspection
May 26th, 2008
Hi all,
I have ACESM, when i do traceroute from PC to the servers behind ACE im getting the next hop as the ACE IP address all the time like the follwoign example:
1 <1 ms <1 ms <1 ms ACE-IP
2 3 ms 3 ms 3 ms ACE-IP
3 3 ms 3 ms 3 ms ACE-IP 4 3 ms 3 ms 3 ms ACE-IP 5 3 ms 3 ms 3 ms ACE-IP 6 50 ms 50 ms 53 ms ACE-IP
i know there is an icmp inspection which might bloceked this ... but how can i disable it ??
please advice
Roble Mumin Mon, 05/26/2008 - 03:22
Hi Hassan,
try following config and apply it to the vlan pointing towards the clients. What you need to do is inspect the ICMP traffic.
access-list ICMP line 10 extended permit icmp any any
class-map match-all ICMP-INSPECT-L4CLASS
description ICMP fixup - L4 Class
2 match access-list ICMP
policy-map multi-match ICMP-Policy
description Inspect ICMP
class ICMP-INSPECT-L4CLASS
inspect icmp error
interface vlan xyz
service-policy input ICMP-Policy
Hope it helps
Roble
shday Thu, 08/04/2011 - 15:23
I have the same problem.  I want to be able to ping through the ACE to the backend layer 2 vlans from a server outside the ACE.  This is what I have configured and does not work.  Vlan302 is the L# vlan that allows all traffic into my ACE.
access-list icmp line 10 extended permit icmp any any
class-map match-all icmp-allow-inspect
  2 match access-list icmp
policy-map multi-match icmp-allow-inspect-mmpl
  class icmp-allow-inspect
    inspect icmp error
interface vlan 302 - public facing VIPs- ingress
  ip address 74.113.93.37 255.255.255.224
  alias 74.113.93.36 255.255.255.224
  peer ip address 74.113.93.38 255.255.255.224
  service-policy input mgmt
  service-policy input icmp-allow-inspect-mmpl
  no shutdown
interface vlan 308 - server - L2
  ip address 10.62.22.130 255.255.255.192
  alias 10.62.22.129 255.255.255.192
  peer ip address 10.62.22.131 255.255.255.192
  no shutdown
