Video Conf unit connected to BRI interfaces
May 26th, 2008
I have a 2851 router with E1 interface connected to an ISDN network provider and a BRI interface connected to a Sony PCSA-B384S Video Conferencing unit.
I want the VC unit to be able to dial via the BRI circuits and "break out" through the E1 (ie. an ISDN call all the way through the router).
I have a layer 1 connection between the VC unit and the BRI, but the VC cannot establish a call.
I have attached a config file.
I know that q931 debugs would be useful and I will try to obtain these shortly, however, any help you could give based on the attached config would be much appreciated
Richard
Overall Rating: 5 (1 ratings)
paolo bevilacqua Mon, 05/26/2008 - 01:29
  • Hall of Fame,
    Founding Member
Have you used crossed BRI cables as detailed at:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_configuration_example09186a008010ef6c.shtml
Note:
- missing network-clock-select for E1 interface
- BRI wic must also network-clock-participate
- you don't need power-inline under bri interfaces.
- depending on how the video unit is set, you may or may not need isdn static-tei 0
- suggest you put both bri in trunk-group and reference the latter with a single DP, for ease of configuration and control.
- said DP will likely need "forward-digits all", else no calling number will be sent.
After that, if still doesn't work, debug isdn q931 is definitely needed.
richardbuxton Tue, 05/27/2008 - 03:59
Hi - thanks for your quick response.
I have configured the network-clock as suggested and removed the power-inline and static-tei commands.
The situation is now much better - I have Layer 2 established on the VC unit BRI0/2/1(see attached).
However, when I dial into any VC test numbers the call connects but then is disconnected within a few seconds (before any video is sent/received).
The Q931 trace is also attached (VC Debug.txt)
Any suggestions?
RIchard
paolo bevilacqua Tue, 05/27/2008 - 04:14
  • Hall of Fame,
    Founding Member
Hi, the device attached to BRI is disconnecting:
130317: May 27 12:50:17.003 BST: %ISDN-6-CONNECT: Interface Serial0/0/0:12 is no
w connected to 01753723849 N/A
130318: May 27 12:50:17.007 BST: %ISDN-6-CONNECT: Interface BRI0/2/1:1 is now co
nnected to N/A N/A
130319: May 27 12:51:11.059 BST: ISDN BR0/2/1 Q931: RX <- DISCONNECT pd = 8 cal
lref = 0x0C
Cause i = 0x8090 - Normal call clearing
Please send output of "show network-clocks" to eliminate any possible problem in that area.
Beside that, you should find from the device why it is disconnecting.
richardbuxton Tue, 05/27/2008 - 04:43
See ISDN and clock status below.
It does seem like the VC unit is disconnecting the call. The VC unit works fine if it is connected to a public ISDN network (ie. not through the VGW).
I will see what debug is available on the VC unit - it seems a little limited!
Richard
Global ISDN Switchtype = primary-net5
ISDN Serial0/0/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
2 Active Layer 3 Call(s)
CCB:callid=9329, sapi=0, ces=0, B-chan=14, calltype=VOICE
CCB:callid=932A, sapi=0, ces=0, B-chan=13, calltype=VOICE
Active dsl 0 CCBs = 2
The Free Channel Mask: 0x80000FFF
Number of L2 Discards = 0, L2 Session ID = 105
ISDN BRI0/2/0 interface
******* Network side configuration *******
dsl 4, interface ISDN Switchtype = basic-net3
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 64, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 4 CCBs = 0
The Free Channel Mask: 0x80000003
ISDN BRI0/2/1 interface
dsl 5, interface ISDN Switchtype = basic-net3
Layer 1 Status:
ACTIVE
Layer 2 Status:
Layer 3 Status:
Active dsl 5 CCBs = 0
Total Allocated ISDN CCBs = 2
TETBURY_ROAD-VGW-01#show network-clocks
Network Clock Configuration
Priority Clock Source Clock State Clock Type
1 E1 0/0/0 GOOD E1
10 Backplane GOOD PLL
Current Primary Clock Source
1 E1 0/0/0 GOOD E1
paolo bevilacqua Tue, 05/27/2008 - 04:52
  • Hall of Fame,
    Founding Member
Hi, sorry I should have asked if you have:
network-clock-participate wic 2
Problem might be limited to that.
richardbuxton Tue, 05/27/2008 - 04:57
Yes, this was already switched on.
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
The VC unit disconnects and gives a message along the lines of "remote terminal not compatible with this bbonding method"
Thank you
Richard
paolo bevilacqua Tue, 05/27/2008 - 05:05
  • Hall of Fame,
    Founding Member
I'm not sure, b-bonding presupposes multiple calls, but only one is seen from the VC.
I don't think the cisco config can be improved from what you have.
richardbuxton Tue, 05/27/2008 - 05:59
We are going to see what options are available on the VC unit - maybe something on here causing the problem.
We are much further forward with this issue thanks to your assistance - thank you very much.
Richard
paolo bevilacqua Tue, 05/27/2008 - 06:05
  • Hall of Fame,
    Founding Member
Thanks for the appreciation and good luck!
johncaston_2 Sun, 06/15/2008 - 17:58
Hi Richard,
I've been asked to do the same thing for one of our clients. Just wondering how you got on - did you get the problem resolved in the end?
richardbuxton Sun, 06/15/2008 - 23:22
Hi John,
Unfortunatley not! With the help of the forumn I managed to get the BRI layer 1 and 2 established, but when the VC unit tries to establish a call it clears after about 20 seconds with a message "not compatable with this bonding method".
If you find a solution, please let me know!
Richard
