PIX: Port-Redirection problem
CNTSYSNETAG
I have to setup two port redirections on our PIX. I need this two redirections:
Outside-IP 212.6.1.1 to SSN 10.10.10.2
for port 443 (HTTPS).
Outside-IP 212.6.1.1 to SSN 10.10.10.253 for port 23 (Telnet).
The access should be possible from any source IP address (not only specific hosts).
I think, first I have to add to static routes. I've got already one:
static (SSN,outside) 212.6.1.1 10.10.10.2 netmask 255.255.255.255
But I cannot add a second static router for 10.10.10.253. Any idea what I have to do to get this work?
Thank you!
5 Replies 5
m.sir
Level 7
Level 7
You can use static PAT for that - it means traffic for port 433 will be redirected to 10.10.10.2 and traffic for telnet to 10.10.10.253
static (SSN,outside) tcp 212.6.1.1 443 10.10.10.2 443 netmask 255.255.255.255
static (SSN,outside) tcp 212.6.1.1 23 10.10.10.253 23 netmask 255.255.255.255
M.
Hope that helps rate if it does
Thank you! Do I also have to create Access-Lists or are these static routes enough to get this work?
Yes you need permit traffic with ACL
access-list out_in permit tcp any host 212.6.1.1 443
access-list out_in permit tcp any host 212.6.1.1 23
access-group out_in interface outside in
M.
thank you, but I get the following errors when I try to add the access lists:
ERROR: % Invalid input detected at '^' marker.
(Invalid input at "23")
Result of the command: "access-group out_in interface outside in"
(Invalid input at "t" from word "interface")
Sorry, now it works. Thank you!
