Mesh Registration takes hours!
May 26th, 2008
We have a mesh implementation, the problem is this: it takes 3 - 4 hours for the MAP to register to the WLC. Has anyone experienced this before? Has anyone have an idea why it takes this long? By the way, This is just a point-to-point mesh network. Thanks.
Richard Atkin Mon, 05/26/2008 - 09:52
This was a common problem in older code releases. What version of code are you running on the Controller, and what model MESH AP's are you using?
engineerangelo Mon, 05/26/2008 - 19:00
We're using the newest version MESH. The APs are both 1242AG converted to LWAPP.
dennischolmes Tue, 05/27/2008 - 04:01
Do you have the MAC addy of the AP added into mac filtering section? If not, it will associate eventually but as a blacklisted AP.
engineerangelo Tue, 05/27/2008 - 22:55
Yes, the MAC address has already been added to the WLC. This is the scenario that we've done: we tested how fast the MAP would register to the WLC several times by doing power cycles on the MAP. Sometimes it would register in just 5 mins and sometimes it takes 3 hours to register.
dennischolmes Mon, 07/14/2008 - 06:20
there is a dhcp scope with the proper VCI identifier for your MESH APs and OPtion 43 enabled right? Did you add the bridge group name as well?
engineerangelo Tue, 09/16/2008 - 00:44
The bridge group names are the same on both. Sometimes the MAP registers quickly.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
